thank you for your reply,
I want to use the second way but without tracking each vehicle and mark the position of each one ,the computer will look at all of the motion vehicles and plot a motion vectors for every pixel witch are used for estimate the velocity, but there is many algorith-ms for the calculate of motion vectors with optical flow, witch one is good ?, and how to obtain the velocity from that motion vect-ors?
If you 'want the computer to do it', then you must tell the computer how to do it step by incremental step. That's what programming is about.
To keep track of several vehicles, you will use array variables.
The vehicles have different velocities. Your code must distinguish how much ground is travelled by each vehicle per frame, or ten frames, or whatever your time window is.
Then you average their motion.
Whether you track one vehicle, or several...
You will have to deal with foreshortening. Distances in the background are different from distances in the foreground. This affects resolution which affects accuracy.
This is where geometry and trig enter in. To get accuracy within 10% you must know real distances to 10%. To get accuracy within 5% you must know real distances to 5%. Etc.
If you're writing your own code then the labor-intensive part will be to look at groups of pixels and distinguish what is a vehicle.
Do you have color video? Then it's easiest to identify a vehicle as pixels with red or green or blue content. It's more or less unique to each vehicle that you're tracking.
If you have black & white video then your code must recognize shapes and patterns that resemble a vehicle. Then it searches for those same shapes and patterns in an area of the next frame where you would expect the vehicle to have moved to.
Labor intensive. Don't know if anyone is marketing (free or otherwise) a program that does the above in the ways your project requires.
thank you,
I have a color video with optical flow i will plot the motion vectors of all the pixels of each frame, and i think to calculate the sum of all motion vectors and divide the result on the time frame ,to obtain the mean velocity in the frame.
