gordon_dhiman
Newbie level 6
Hi all...
There was not much problem setting up an openknoppix cluster using the live cd, two pcs and a cross cable.........now when i try the open mosix terminal server nothing happens......my slave node is not detected........the network card supports boot on lan..........as does my bios.......and the network card is listed in the terminal server setup.
If i boot the slave pc after setting up the terminal server on the master........i see that the slave has assigned itself an ip address in the range given in the terminal server on the master node.......and in the slave node the openmosix view is showing its own slave node as part of the cluster......but in the master node there is nothing in openmosix view...
Is it that i need a seperate dhcp server and this thing needs a min of three pcs......i have seen the entire site and other help sites.
