Open loop settings??
pekachoo007
Member level 2
Is this setting valid for finding the Open loop gain of the opamp.
If yes then hows its done in cadence spectre.
There must be no OP capacitive output load, remove one capacitor.
Use high L and C values, e.g. 1000 H / 1000F or higher, depending on the frequency range of interest.
The opamp is actually an error amplifier part of a linear voltage regulator. The output capacitance represents the gate capacitance of pass transistor.
Using 10^12H and 10^12F for L and C values for the frequency of operation of 10MHz.
A small question. Why do you need inductance in feed back? Can't you directly connect the -ve terminal of the opamp to the required DC potential and measure the open loop gain? Correct me if I am wrong.
O.K., in this case the regular output C should be used.
What settings should I give to Cadence Spectre for simulation results of gain and phase margin
Run an ac simulation for your frequency range of interest, then display gain (dB20 scale) and phase.
Because you need the DC control loop.
Calculate its cutoff frequency resp. time constant! DC control will take much too long for your simulation period: don't forget the output impedance of the opAmp.
I have done this but not satisfied with results.
What would be use of these extra calculation, how they would be helpful. As you suggested, could you provide the formulas also.
Set AC source with AC Magnitude=1 V, DC Voltage=1.1 V, f=10 MHz
db20 = 44 db
What would be phase Margin, is it 180-67= 113??
Just use the known or estimated value of the opAmp's DC output resistance R and calculate the cutoff frequency of this low-pass filter RLC time constant; its inverse is the time constant of your DC input control voltage, i.e. before this time you can't expect to get the correct input bias.
At this cutoff frequency you can neglect the value of your chosen L=10^12H impedance against the opAmp's DC output resistance R value - let's say this is 100Ω - so the cutoff frequency - considering your chosen C=10^12F value - fco = 1/(2πRC) =0.16*10^-14 Hz, its time constant is τ = 2πRC = 6.28*10^14 s ≈ 20 million years. After this time you can expect that the input bias has reached about 63% of its correct value, more than 99% after 5τ ≈ 100 million years.
SPICE achieves a correct bias point in "no time" because it disables all Ls and Cs during initial transient solution.
Reactions: erikl
    erikl
pekachoo007, is the max. gain of 40 dB the value you have expected?
Why a dc voltage of 1.1 V ?
Why to fret about million years, the values are for the test bench.
Around 70.
What it should be then.
You have decided to apply a dc voltage of 1,.1 volts - and my question was "why this value" or "for what purpose"?
Applying a certain voltage should serve a certain purpose.
The purpose might be certain, with the certainity principle lying somewhere.
So - you dont know why?
This is not a big problem - however, in this case you simply should ask instead of (blindly) using a dc component without knowing its purpose.
