biolycans
Member level 2
Why in the simulation of the open loop gain of an operational amplifier I have to use a voltage source AC 1V ?
I know that AC 1 means that the output will plot correctly in db as gain. If I plot volts in the output versus volt in the input, I will have really big values of the gain in the op amp, but my question is related to the AC sweep.
I know that the AC sweep is a small signal analysis but in this case why I am using a signal AC of 1 volt amplitude instead of a really small signal (10 mV for example or even less) for the small signal analysis ?
Regards,
Joaquin
Regards,
Joaquin
