Hi, just as picture, no more data!Hello, is something written on its body? No model number or something?
Hi,Are you sure this is a relay? It looks more like a circuit breaker with a reset button to me.
Brian.
Hi,Why do you need it the datasheet? What caused this concern?
It looks like a typical RCCB. If I'm not mistaken EU has much higher ratings than but are 25 to 30 mA for small units while North America calls them RCD and are rated at 20 mA imbalance from leakage.View attachment 185402
Residual-current device - Wikiwand
A residual-current device (RCD), residual-current circuit breaker (RCCB) or ground fault circuit interrupter (GFCI) is an electrical safety device that interrup...www.wikiwand.com
It is basically a very high inductance CM choke that acts as a solenoid to trip the breaker on imbalanced AC currents with the presumption that is caused by unsafe external leakage to ground
Not sure if it will help. You can post the pic and rating in digikey forum. Sorry. This relay is not familiar to me.Hi,
Thank you for detailed information, its in a PRCD and its rating is 10mA.
I want to know the manufacturer and coil resistance.
Why don't you get one and measure it.Hi,
The R is about 3.57 K. Do you any supplier for this, I could not find any.Why don't you get one and measure it.
What value of L and R would you expect for each winding?
I doubt anyone can recognize the supplier from the internal photo.The R is about 3.57 K. Do you any supplier for this, I could not find any.
