Open drain pins in pic microcontroller
Murugesh_89
Full Member level 5
India
I am using the PIC18f6310 microcontroller. I know that the pin A4 is open drain output. So i can't able to drive using A4 as like other i/o.
Is there any other pin in pic which is having the same function?
Thanks,
Murugesh
Page 190 in datasheet..take care in I2C mode
Selection of any I2C mode with the SSPEN bit set,forces the SCL and SDA pins to be open-drain,provided these pins are programmed to inputs by setting the appropriate TRISC bits. To ensure proper operation of the module, pull-up resistors must be provided externally to the SCL and SDA pins.
I did not use SCL and SDA pins for I2C purpose. I just want those two pins as normal digital outputs(SSPEN = 0). so can i have circuit as follows?
SCL pin - 330E - LED(Anode) - LED(Cathode) - GND
SDA pin - 330E - LED(Anode) - LED(Cathode) - GND
You can still use A4 as an input and it still works as an output if you provide it a current source from VDD. All an open drain output can't do is produce a current by itself, if you add a pull-up resistor to VDD it still works as a logic output as normal.
Brian.
