Murugesh_89
Full Member level 5
In pic microcontroller RA4 is the open drain output pin. I know that if this pin is configured as output we need to pull up with a resistor to drive. Pull down this pin will not work to drive high value.
If we configure this pin as input will this pin capable of detecting both high and low value?
I mean that i want to know, shall we pull down this pin to detect the high value and pull up this pin to detect low value.
Or this pin should be pulled up only on configuring this as either input or output?
Thanks,
Murugesh
Thanks,
Murugesh
