cupoftea
Advanced Member level 6
We need an opamp for supply rails of +20V and -3v3.
One's a buffer, the other is used with negative feedback to give a certain voltage at the output of a linear regulator.
Can you confirm that none of the following opamps will ever latch up when they are given input voltages to either pin (inv or non-inv) , which is within the supply rails, but outside the common mode input range?
LM2902,
TL084C
TL084H
TL084X
TL074X
LM348
LM342
LM2902,
TL084C
TL084H
TL084X
TL074X
LM348
LM342
