Opamp parameter that is important when driving load of 600 ohm
danesh
Full Member level 3
Full Member level 3
what would be the parameter i have to look in to in choosing opamp to drive load of 600 ohm or any mic, without loading audio signal. Thanks in advance
Re: op parameter
Look for Max. output POWER of the opamp.
Re: op parameter
you may choose half-bridge or full-bridge structure to try it
op parameter
Buffer stage is needed,and P.E.Allen explain this in details.
Regards!
Re: op parameter
danesh,
You often have to "work the problem in reverse". Typically, Op Amp current drive capability is specified indirectly, e.g., guaranteed output with a 2K load = +/- 10V. From this you can conclude that the Op-Amp is capable of supplying 5 mA of current. With a 600 Ohm load, this fictitious Op Amp could provide 3V Peak = 2.121Vrms.
I'm confused about the phrase "or any mic". Why do you want to drive a microphone?
Regards,
Kral
Re: op parameter
yes i need to drive a mic at 2.2k impedance at 1kHz
