iamxo
Full Member level 4
- Joined
- Mar 22, 2006
- Messages
- 225
- Helped
- 16
- Reputation
- 32
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Southeast Asia
- Activity points
- 2,493
pipeline adc
As we all know, in pipeline ADC the capacitor size could be scaled down in latter stages together with the opamp current ( however the GBW should be constant).
However, when i was designing the opamp for MDAC(which is used in latter stages, that is to say small cap could be used), i found that i need large current to maintain the closed-loop GBW, because the parasitic cap at the gate of input transistor is large enough to be comparable to the caps in MDAC, which leads to small feedback factor and results in small closed-loop GBW. it degrades the settling of the closed opamp.
So, does anybody face the same problem? How did you solve it? thank you all~
