jalalif
Newbie level 2
opamp layout
Hi everybody,
I got a problem recently that I don't know how to solve it. I really appreciate your helps and comments on that:
problem is: I have layouted a two stage Opamp with switched cap CMFB. The Opamp works fine in schematic,the extracted file including parasitic C also works very well but if I include parasitic R, it doesn't work and the peoblem is that although CMFB circuit does his job well and the common voltage of output is the correct value(at mid-rail),but Vout+ and Vout- have some diffential errors. I guess that should be due to the fact that the layout is not %100 symetric and paths to Vout+ and Vout- may have diffenet resistances, I tried my best to make the layout symetric and draw the paths of Vout+ and Vout- the same length but problem still remains. The differential diffence between Vo1+ and Vo1-(outputs of firts stage of Opamp) are around 20mv but the error gets much bigger when we look at the Vout+ and Vout-(outputs of the second stage of the Opamp)due to the gain of the second stage.
Thanks a lof for your help
Hi everybody,
