robismyname
Full Member level 6
- Joined
- Jan 17, 2008
- Messages
- 390
- Helped
- 11
- Reputation
- 22
- Reaction score
- 9
- Trophy points
- 1,298
- Location
- Central Florida
- Activity points
- 4,603
I put together a lt6203 opamp with a low pass filter on the non inverting input. My circuit is attached.
I connected a function generator on the non inverting input of the opamp and an o-scope on the opamp output (channel 1). Channel 2 of the oscope is just connected to the function generator to read the output signal going into the opamp.
It appears that my opamp is working. I say this because the o-scope is telling me the output signal of the opamp (channel 1) is much larger than the signal of the function generator (on channel 2). see png's attached.
It appears that my filter is working. I say this because when I increase the frequency of the function generator I noticed the output signal of the op-amp (channel 1 of the o-scope) gets smaller and smaller as I increase the frequency up and past 5MHz........see png's attached
Frequency O-scope-Channel 1 (Output of Opamp)
500kHz 10.4V
1MHz 10.6V
1.5MHz 7V
2MHz 4.8V
2.5MHz 3.7V
3MHz 2.3V
3.5MHz 1.48V
4MHz 1.08
4.5MHz 680mV
5MHz 460mV
There are some things I noticed that seem to make me a bit skeptical about my test setup and if I am interpreting the data correctly. They are:
1) My signal amplitude on the function generator doesn't match the reading from the oscilloscope. When I generate 5Vpp with the function generator why am I only reading a portion of the signal amplitude on the oscilloscope?
2) Why is the amplitude increasing when I increase the frequency?
Amplitude Freq Amplitude measured on O-scope
5Vpp 500kHz 132mV
5Vpp 1000kHz 250mV
5Vpp 1500kHz 372mV
5Vpp 2000kHz 494mV
5Vpp 2500kHz 600mV
5Vpp 3000kHz 748mV
5Vpp 3500kHz 828mV
5Vpp 4000kHz 928mV
5Vpp 4500kHz 1.03V
5Vpp 5000kHz 1.12V (not enough room to attach)
3) Why is the output waveform of the opamp trying to look like a square wave. Shouldn't it resemble the signal made by the function generator? They looked similar in my multisim simulation.
4) What would be the ramifications if I removed the .1uF coupling capacitor out of the circuit?
500kHz 10.4V
1MHz 10.6V
1.5MHz 7V
2MHz 4.8V
2.5MHz 3.7V
3MHz 2.3V
3.5MHz 1.48V
4MHz 1.08
4.5MHz 680mV
5MHz 460mV
5Vpp 500kHz 132mV
5Vpp 1000kHz 250mV
5Vpp 1500kHz 372mV
5Vpp 2000kHz 494mV
5Vpp 2500kHz 600mV
5Vpp 3000kHz 748mV
5Vpp 3500kHz 828mV
5Vpp 4000kHz 928mV
5Vpp 4500kHz 1.03V
