oliglaser
Junior Member level 3
- Joined
- Feb 26, 2010
- Messages
- 31
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Manchester, UK
- Activity points
- 1,688
Hi all,
I'm designing a PIC32 based USB oscilloscope. I need a dual supply for the opamps as it simplifies input impedance and level shifting. I selected a unregulated +5V to +/-5V DC to DC converter (needs to be isolated so this limits my choices here) and then I was either going to use +/-3V LDOs in front of this to provide the supply for the opamps, or just filter the +/-5V instead.
The problems I have with the +/-3V idea are finding a suitable hi-speed, fet based opamp that works with the supply. I have found one or two possibilities but neither are ideal, one is right at the bottom of the supply range (5-24V) and does not have rail to rail inputs), and the other would have to be used outside recommended supply range.
The problem I have with the +/-5V idea is I am worried about the ripple on the supply, and whther it will affect the ADC and opamps that much. The ADC is only 8-bit, so I am thinking I am worrying too much here, but as I am no expert in these matters I would like to hear any opinions. Also what filtering technique would be best?
So the questions are:
1. Which option do you think is best?
2. How would you implement it?
Thanks in advance..
Thanks in advance..
