guamak_menanak said:I'm using T-Spice from Tanner for my simulation. However, T-Spice doesn't have the 'CMRR=VDB(OUT)' syntax, is there any other way to simulate CMRR??
Yes, you are right. The DC component of V1 and V2 should be set to the proper common input voltage.lunren said:Should the DC component of V1 be in the range of common input voltage instead of 0?
