OP AMP why input pmos transistor
olzanin
Member level 1
Member level 1
pmos transistor
Hello,
why most of the opamps I have seen have pmos differential input stage and not nmos. Is it regarding
noise or other effects too?
Thanks.
olzanin
op amp,transistor
due to noise reasons and ground referenced signal design style mostly
pmos opamp
One reason is that PMOSFETs have lower flicker noise.
pmos inpute opamp
Next reason is that the body voltage of the MOS differential pair, which is the NWELL for PMOS, could follow the input common mode voltage. Therefore the CMRR is much higher because the body effect and the mismatch of the body effect of the two differential pair MOS is avoided.
If the process have an isolated PWELL you can also use NMOS.
