[SOLVED] Op amp testing question about feedback loop
chandlerbing65nm
Member level 5
Member level 5
But what is the purpose of connecting the feedback at the positive input, rather than the negative input.
If you connect the feedback to the negative input you will end up having a positive feedback. That's the purpose.
you need to look at the WHOLE circuit - not just the op-amp bit ...
The way to test this is easy
Imagine TP1 rises
1) V+ of DUT will increase
2) output of DUT will increase
3) V- of Aux opamp will increase
4) TP1 will drop
Therefore the loop is negetive feedback and stable
Now assume you connect to negetive input
1) V- of DUT will increase
2) output of DUT will decrease
3) V- of Aux opamp will decrease
4) TP1 will increase further ...
positive feedback !
