[SOLVED] Op-amp output resistance measurement
Junus2012
Advanced Member level 5
Italy
Hello friends
So far you have told how to simulate the output Impedance of the operational amplifier (After long discussion :)) , and As you know I am in the phase of the measurement . I attached you this method of measuring the output resistance and I would like to hear your suggestions and opinions too
Regards
If I remeber right, you have been previously discussing open loop output impednace of an OTA, which is a somewhat different problem.
Anyway, the present measurement circuit looks straightforward. Any questions or problems related to it?
Ok FvM
I just wanted to confirm with you expert guys :), I would consider your reply as a confirmation to use this setup
Thank you very much
