Op amp non inverting amplifier not working
I14R10
Full Member level 3
Full Member level 3
Hello
I'm trying to build an amplifier with Op amp (TL072). I built a simple circuit like this
But I don't get anything on output. Weird thing is, I get huge amplification if I don't connect R_f and R_2. As soon as I put any resistor there, my output drops to 0.
I've also simulated a random 2 op amps in LTSpice and this exact circuit doesn't work there either.
What am I doing wrong?
You have to provide a bias return path for the NI input. Say a 1M to ground,
since you are AC coupling. Or DC couple and offset V2 waveform.
When no fdbk is used the OpAmp is open loop with a typical G of
Regards, Dana.
Yes, missing N.I. bias. To achieve useful operation point with given feedback network, it should be biased to e.g. 0.5 V.
I want only positive half of the signal to be amplified. Do I still need to do N.I.bias?
Also, I'm starting to doubt if my opamps are good. I've also made voltage follower (wire from output to - input) and my opamps are still getting a huge amplification on the output.
Thanks everybody. Somehow I thought op amps were some magical devices that doesn't need biasing.
They are very useful devices, but certainly not magical.
Both inputs need a path for their input bias current no matter how small it is.
Also if you want to operate them from a single-supply they need to be single-supply or rail-rail types, or the inputs need to be biased at 1/2 the supply voltage (virtual ground).
