op amp intergrator differentiator
mess123
Member level 5
Member level 5
Why is the input signal always given to the inverting terminal of op-amp in integrator and differentiator circuit? Can't we give the input signal in +ve terminal and obtain integration and differentiation?
Yes, but you need two matching RC combinations to form a differential integrator/differentiator.
Feeding the input to the positive input directly results in a 1+∫xdt respectively 1 + dx/dt function.
Consult analog circuit design text books for details.
