tia_design
Hi, guys,
How do you guys reduce the input offset for a high DC gain (say 120dB) CMOS Op Amp(VDD=3.3V)? One way is to introduce an auxiliary port parallel to the main port, then the callibration voltage is applied to this auxliiary port. Such method is actually not good for high gain Op Amp.
I found the Texas Instruments TLC4501 CMOS Op Amp (https://focus.ti.com/lit/ds/slos221b/slos221b.pdf) using digital trimming to get as low as 10uV input offset. Does anyone has idea of this scheme? or how can I find related patents or paper?
Thanks very much!
Thanks very much!
