terranpro
Trying to follow the example in Allen's book for a two stage op-amp design (6.3)
Could someone explain the constraints placed on the common mode input range?
Vin_max = VDD - sqrt(I5/beta3) - |VT03max| + VT1min
Vin_min = VSS + sqrt(I5/beta1) + |VT1max| +VDS5(sat)
I don't understand his terminology, what is VT03max, and what is VT1min and max?
I tried to derive these on my own by writing the large signal Id (saturation) equations, and keeping the constrains (Vds versus Vgs-Vt) satisfied; is this the right approach?
Also, If I have an output swing range limitation, how/where do I consider that?
i would appreciate as much explanation as possible (i am a beginning analog ic student) - thanks
