somf0872
Member level 5
current amplifier op-amp
How the Op-Amp can be designed as a current Amplifier?
For ex. i have an Op-Amp OP213 whose max short circuit current Isc=30mA. If I want to draw 300mA from this Op-Amp, what sort of configuration should I use?
Firstly it is possible or not? If yes then pls explain how .....If no then ple let me know any other Op-Amp part number that can go upto 300mA with low offset voltage and input bias current.
--X--
--X--
