Only 3.5V output in MOSFET logic gate with 9V supply?!
Newbie level 1
Hello there,
recently I've been building an logic XOR-gate with a few N-channel MOSFETS, a few resistors and two push buttons. Everything was working fine when I put a LED on the output; It only lighted up when one button was pushed. But when I tested the Voltage across the resistor and LED with a multimeter, I saw that there were only 3.5 Volts.
The voltage seems to drop across R1.
Can anyone tell me why?
Thanks, AxelanDerGrosse
Ideally, voltage across an LED is fixed. I guess you measured it across the LED. A blue LED can have a forward voltage drop of 3.5 V.
some issues:
* never leave MOSFET´s GATEs floating with respect to it´s SOURCE
* always drive MOSFET´s GATEs with respect to it´s SOURCE. The datasheet specification is V_GS, which means: Voltage between GATE and SOURCE
The absolute voltage (w.r.t. GND) is NOT of interest when drivng MOSFETs.
Klaus
Just expectable. Maximal unloaded 'H' output voltage of this very simple logic gate is about 7 V according to gate threshold voltage, above 2 mA output current, voltage will further drop.
You didn't tell about load resistance.
Write your reply...
LaTeX Commands Quick-Menu:
