eem2am
Banned
two transistor forward converter
hello,
I have built a one transistor forward converter (10W) for 240V 50Hz mains.
It is an isolated version of an otherwise identical one which was non-isolated and worked fine.
However, this isolated one is not working well at all.
I am getting only some 2 Volts across the 11 Ohm load.
It is strange because the MOSFET gate drive pin of the MC34025 is not driving proper gate pulses......it is just giving titchy ones which dont turn the Mosfet on well enough or long enough.
When i disconnect the secondary (so its open circuit) then i can see decent proper gate drive pulses. -but only when secondary is disconnected.
I have disconnected the feedback opto and grounded the current sense to try and get it to give gate drive pulses but nothing works.
I am just wondering if the transformer is passing noise to upset the PWM controller. This would be strange since this transformer worked fine with the non isolated version.
But maybe its inter or intra-winding capacitance or leakage inductance thats causing the problem ?
For the transformer, i did not do interleaved winding but just wound ...
81 turns of primary (one complete layer)...then
71 turns of demagnetisation winding..(2nd layer) .then
14 turns of secondary winding (3rd layer)
.....is this "one on top of the other" winding technique wrong ?
i would be most grateful for replies
hello,
