one member of the MIW1300 power modules series
Rubby
Newbie level 6
Newbie level 6
The **broken link removed** is one member of the MIW1300 power modules series which are low-profile dc-dc converters that operate over an input voltage range of 10-30VDC and provide precisely regulated output voltages of 5V and 12V in both single and dual output configurations. Performance of this device is affected by many conditions. The W13003 has a maximum power rating of 3W and a typical full-load efficiency of 80%, continuous short circuit, 60mA output ripple, built-in filtering for both input and output minimizes the need for external filtering. Also it has limitation of maximum connected capacitance at the output and the power module may be operated in current limiting mode during start-up, affecting the ramp-up and the startup time.
