igeorge
Member level 5
Hello,
I need help to find a circuit to turn on a triac with just a pulse, and a way to turn it off with another pulse
I am using now some latching relays with two coil, but they take too much current -30 mA each time
This application is for a thermostat
From main HVAC i have 28VAC comming in one wire, the common for all ( Red wire) , and has to return to the control on 3 diferent way
1 for heat
2 for cool
3 for air on all the times.
I do not know what is in the HVAC control, but my house thermostat has 3 latching relays
I designed a thermostat, battery operated, so i need the minimum current consumtion.
The relays, take 30 mA each time are Set or Reset
It is two much, so i need the lowest current use from the battery. Moc optocouplers also take 30 mA , and the have to be on all the time, so out of question
Please sugest some reading or schematic
Thank you
1 for heat
2 for cool
Thank you
