Omron SP PLC's like SP10,SP15,SP20
monty_burns_007
Member level 2
Member level 2
Springfield
minilss software
These are PLC's which are programmed with an operator panel.
Now i've got a software for this on PC, it's called MINILSS.
Problem was, i can't find the programming cable.
Even Omron didn't knew of this cable and software.
But I made my own version.
In attachment, the schematic of this cable.
For the soft, PM
Monty 8)
omron sp10
Here's the software guys, for those who were interested...
It runs good on older PC's like 486, Pentium 1 & 2.
On high speed computers like AMD K7 or PIII or PIV, use a delaying tool, otherwise you get a run-time error :(
Have phun :wink:
Monty 8)
omron sp20
Attached:
- Newer version of the minilss software
- Cpukill : a good delaying tool which is needed to avoid run-time errors on faster cpu's
Enjoy...
Monty 8)
/ File deleted
minilss
I search for manual for SP10. Can you help?
MiniLSS - Where have found you?
This text is translated automatically, it can be amusing.
Krzysiu
omron plc sp10
Krzysiu
I have manual sp20 .
give me your email ,i send you
i need scheme cable for Sp 10/20 plc to PC and minilss
omron sp20 software
Krzysiu
[hr:88e40e9171]Thanks. My address is krzysiu(at)op.pl.
Look at post of monty_burns_007. Is it incorrect cable?
cable for plc sp10
Monty_burn_007
Im only a beginer and scored a sp20 and have no key pad to program it.But then I saw your program that might run on my old 486 win95 laptop.
So if it is possable could you please send me a copy of the pc program and the scematic of the cable so I can make one up and then give it a go.
Thanks
Derek :D
program omron sp 10
Hi just wondering in the schematic for cable to suit SP20 supplied in this forum there is no value for the zener diode. Does anyone know what it should be. Thanks, Glenn.
