savvasha
Hello there. I am trying to design on ADS the antenna mentioned on the title. I am having some problems though. Ah, I forgot to mention that I am trying to design the antenna that is mentioned at https://ieeexplore.ieee.org/iel5/8/29739/01353517.pdf.
My problems are the following:
(a) I am using a board with two metal layers, top and botto. How can I define that with the substrate editor on Momentum? I am attaching my current configuration. Is it right?
(b) I have to add two shorts on the design. I am using the command "VIA" but I am not sure what to change at the dialogue window. I am attaching the window also. My top layer is cond2 and bottom cond
(c) While simulating, the program complains that the port is internal. How that can affect my results?
Thanks in advance and sorry for my bad english
