Merlysys
Newbie
We often connect same point of a circuit under test to several instruments if the instruments' input impedance is in the megahoms range. Is it OK to do same with several CD4051BE inputs? Meaning there are several 4051s (say 3) and the same point of circuit need connecting to those 3 chips. How to determine this using the datasheet? Or is it common knowledge based on the IC family?
Inputs referred to are marked in red, CHANNEL IN/OUT.
Datasheet at **broken link removed**
