What you have done is called point-wise division. This may not be same R(t)=U(t)/I(t) under some conditions. Particularly near singularities. I won't go into these details. Recall that division by zero is not defined.
Yes, but in this data series, the current is never zero, otherwise the calculating script throws a divide by zero warning, which it doesn't in this case. - so no zeros.
You must know the waveform: in other words, the voltage a moment back has an effect on the current at the present moment (if your circuit is reactive). Because of Ohm's law, only two of the three (U,I and R) are independent.
As I have said several times, and as it can be seen in the trace, before the pulse - both current and voltage are zero. And the pulse in the trace is the very first after power on.
Simple questions do not have simple answers. I will stop here.
Yes I can agree.
The calculations and respective conclusions are presuming correct I and U measurements.
I'm presuming the measurements are correct until there is valid reason they are not. So far I have not heard any valid reason, "impossible" and "implausible" are not a valid reasons, they are just empty statements, so I kindly ask you to be more serious.
Particularly the current measurement is very implausible, see previous discussion, e.g. post #12.
For which valid reason are you making that claim?
I agree with KlausST that the current measurement channel seems to be inverted. I' d think about possible alternative explanations if I see the pulse response form the start.
You have seen the pulse from start in #21, so I'm still waiting your sentiments.
Since it is in my interest the measurements are correct, I would like to propose that I drop by your lab at your convenience, where you can repeat the measurements with your own apparatus, and even examine the source to your personal satisfaction. And if you don't work for free - then give me your price.
Actually I would personally prefer if the current was positive all the way, I have no use for negative current.
