offset sine wave to square wave
squirrel_41
Newbie level 3
Newbie level 3
Hi guys I have a need to convert a sine wave of 2vpp with a 1.25v postive offset to square wave the sine wave is of low frequency < 40khz
I have multisim and can simulate the circuit I am trying with a op-amp but as soon as I set the sine wave to have a positive offset I lose the square wave.
any help would be much appreciated.
If you simply capacitively couple (i.e. insert a series cap) your sine wave to whatever you're using (op-amp?) to "square it up" with, you should be fine - the capacitor will block the DC component, passing only your 40 kHz sine wave. Without knowing your circuit topology I can't recommend a value, so just choose C > 1/(2*pi*Rin*40E3) where Rin is the input impedance of your squarer-upper... :)
Hi thanks for that I have done very little work with op-amps Im useing multisim Ver 11 is it possable for you to send me a vi
It okay thank you very much I now have it working
Regards
