amic
Member level 5
I desinged an OTA with a gain of 80dB and bandwidth of 45MHz. but getting offset of 0.1 uV...Is such a low offset possible or am I doing some sily mistake in measuring the offset ?
Alles Gute said:With 45MHz BW and without any special design trick(like autozeroing, chopper stabilization...) in 0.18um process. An offset of 0.1uV is definitely unrealistic. Even 0.1mV is pretty doubtful.
amic said:Alles Gute said:With 45MHz BW and without any special design trick(like autozeroing, chopper stabilization...) in 0.18um process. An offset of 0.1uV is definitely unrealistic. Even 0.1mV is pretty doubtful.
may be i need to do the monte carlo analysis then as humungus suggested....
but what u think, would be typical values for systematic offset and random offset if the total offset is supposed tobe 0.1mV ?
Sachin
Sezi said:Alles Gute said:With 45MHz BW and without any special design trick(like autozeroing, chopper stabilization...) in 0.18um process. An offset of 0.1uV is definitely unrealistic. Even 0.1mV is pretty doubtful.
how do you make an autozeroing, chopper stabilization?
flushrat said:typical offset is several mV.
for a simple differential pair, the offset is
Vos=delta(Vth)-(Vgs-Vth)/2*delta(beta)/beta (1)
sigma(delta(Vth))=Ath/sqrt(W*L) (2)
sigma(delta(beta)/beta)=Abeta/sqrt(W*L) (3)
for example, l=0.18u W=50u, Ath~=6mV
one sigma of delta(Vth) is 2mV
Sachin
