Offline LED drive SMPS >50W must have open feedback loop protection via aux coil?
T
treez
Newbie level 1
Hello,
We are doing a 100W led lamp, it is powered by a 100w offline smps.
If the led load goes open, we have an opto which crosses the isolation barrier and shuts down the pwm controller on the primary side.
..but is this enough?...do we also need to have a auxiliary coil in the isolation transformer which gets used for overvoltage protection by relaying an "image" of the output voltage back to a shut down cct on the primary side.?
Or is a simple opto, on its own, enough?
Re: Offline LED drive SMPS >50W must have open feedback loop protection via aux coil?
Depends, how high does the output go in the event of a fault, and how much energy is potentially available?
Maybe you can use the turns ratio on the magnetics to limit the worst case output voltage to something SELV?
Maybe you can just have the magnetics saturate before the voltage becomes dangerous and take out a fuse?
I am assuming that at the 100W level the topology is something a bit smarter then a flyback?
Regards, Dan.
Reactions: treez
    T
Smart Drivers have OVP and UVP with latching hysteresis
Reactions: treez
    T
Thanks, this is a qr flyback running off 400v pfc output.
