cupoftea
Advanced Member level 5
We are doing a 24Vout offline flyback 1A.
We wish to use Inno3-CE controller. (link below)
We have a 4 layer PCB.
So on page 15 of this...
...should we have our internal copper layers running under the transformer, so as to shield
the Innoswitch from the transformer?
As you know, clearance/creepage distances for internal copper layers are much shorter, so I believe we can
have internal layer 2 primary copper as near as 3mm away from internal layer 2 secondary copper pour?
What about going even further, and completely shielding the innoswitch from the transformer by having layer 2 copper
pour coming right from primary to secondary side, and layer 3 copper pour coming from secondary
to primary side?
Also, does the spark gap prevent damage to the innoswitch due to hipot tester voltage going
well over 4kv due to the reaction with the y capacitor across the transformer?
Would it be Ok for us to put the spark gap on an inner layer? If so then how far apart should be the primary and secondary side pointed copper bits?
Also, in a no-fan , small , totally enclosed (no vents) plastic enclosure, with the size of source copper pour
shown in page 15 (above), what temperature would you say the Innoswitch would rise to? (40 degC ambient)
to primary side?
