T
treez
In an offline Flyback SMPS, using a plastic case TO220 FET such as FSCQ1565, do you agree, its better to connect the FET heatsink to primary ground rather than earth? (Wouldn’t common mode EMC be worse if it was connected to Earth?)
Also: Same question as above but for the secondary TO220 diode?
FSCQ1565 datasheet
FSCQ1565 datasheet
