Obtaining 3-ph system from 2-ph
sirvo
Newbie level 2
Newbie level 2
Brazil
Hi there,
We have been trying to generate a 3-ph from a 2-ph system using only resistors. I was wondering if you could help me with that.
We have a 3-ph system connected to 2 transformers. After the transformers, there are 2-ph plus a ground.
So, we tried some delta-wye connections on this 2-ph + ground outputs to obtain a 3-ph system, however, we can`t get a correct amplitude neither the angle.
Also, it`s not possible to access the transformers.
Is there any solution for this?
Thanks in advance.
There are three basic methods of connecting 3-phase devices (motors) to single phase:
1. static
2. rotary
3. VFDs based on Hex bridge ..
All are briefly descibed in the following urls:
https://dcacmotors.blogspot.com/2009/04/running-3-phase-motors-with-1-phase.html
The required phase shift can not be created with resistors - that's out of question ..
It can only be done with devices such as motors or 3-phase transformers .. see attached picture ..
IanP
Hi IanP,
My purpose is not powering a motor. I just want generate the 3-pf from 2-ph.
Well, I did a simulation using PSIM and did get what I want. However, not practical.
Could you analyze the schematic and the result?
Thanks again.
