Obtain total output capacitance in Virtuoso
dtzounakos
Member level 3
Member level 3
From analog books and papers I have read that the total output capacitance of this
circuit is
Ctotal = CL+CDB_T9+CGD_T9+CDB_T8+CGD_T8
My question is: Searching "Results Broswers" there are two capacitance CGD and
CDG.Obvioussly these capacitance are mutual and different each other
Which capacitance (CGD or CDG????) should i use in the above equation in
order to obtain the correct total output capacitance?Below i upload
the relevant circuit (Opamp)
use Cdg,that means gate voltage changes with drain voltage.
It seems reasonably to use Cdg parameter. But take a look at this paper......
