OA routing in Encounter
eklikeroomys
Full Member level 3
Full Member level 3
South Africa
Has anybody routed an OA design in Encounter? According to my understanding, if you create an OA design , you do not need to specify any LEF in Encounter. However, when I try to route my OA design, the router requests a LEF file? This is confusing
If you specify set rda_Input(ui_oa_reflib) in .conf file, it will not ask for LEFs. Otherwise, it will asssume that the flow is LEFDEF Flow and will ask for lef files.
Regards,
R.Srideeoa
Do I have to enter this step manually? If so, where is this .conf file and how do I specify this?
---------- Post added at 10:19 ---------- Previous post was at 10:02 ----------
I have found this .conf file, and the set rda_Input(ui_oa_reflib) option, should I remove the set rda_Input(ui_leffile) option?
Yes. You should remove ui_leffile option for OA flow.
And say loadConfig a.conf 1
Regards,
R.Srideepa
