danny davis
Banned
At work they have tektronix O-scopes 2212, 2221, 2445
The O-scopes have a Percentage for measure voltage percentage , to measure the voltage percentage of 2 different voltages
Can I use this to measure the input signal of a op amp on ch1 and the output signal on ch2
The Percentage would tell me the voltage difference percentage between the two signals from input and output of that stage
My question is , one I got the percentage from the O-scope reading , is this the GAIN? or how can i calculate the gain from this percentage?
It's a voltage ratio between the input signal and the output signal
The O-scope will display the voltage RATIO
This Voltage ratio is the GAIN of that stage?
