P
ParkerMike
When measuring logic switching transitions in auto trigger mode on an O-scope won't tell you where the trigger event starts? only in single sweep mode it tell you where the trigger event is?
Each O-scope is different using the single sweep mode, some indicate a "T" or a "DOT" on the O scope to tell you this is where the trigger event starts
When using the Auto mode or Normal mode, using the external trigger won't tell you on the o-scope where the event trigger started?
