o/p of dickson charge pump with dynamic cts is not coming
kshamamishra
Newbie level 3
Newbie level 3
this is the dickson charge pump ckt using dynamic cts switches bt its output vltg is not increasing above vin
plz help
thanks
Questions:
* Your schematic has several stages. Did you try a single stage? Did it work?
* Are your mosfets biased to a sufficient volt level so that they turn on? (It needs to be greater than the node at the source pin.)
* Which capacitor accumulates the output voltage? The neighboring mosfet needs to be biased several volts higher.
