number of the output transistors
drabos
Full Member level 6
Full Member level 6
What are the main reasons in the decision about the numbers of the transistors in an output stage?
So, using 10 MOSs or 20 MOSs or more...
Thanks,
it is mainly the consideration on the output capacitance and the power sourcing capability...
    drabos
A.. Anand Srinivasan is right. The more output transistors (we call it fan out devices), the more capacitance. I am not too sure about Analog IC, but in digital IC it is often a better practice to limit the number of fan out devices to be less than 4 whenever possible.
    drabos
For MOS transistor fanout of 50 is possible....It all depends on total load capacitance offered.....more the fanout slower the device....
But How power sourcing capability will affect Fanout in MOS?
    drabos
more MOS means the power supply should be capable of supplying a lot of power especially when the MOS undergoes transition....
    drabos
hi all,
The more output transistors (we call it fan out devices), that will effect on directly the more capacitance.
thanx....
    drabos
