Ns2 Extension with directional Antennas
tibm
Member level 1
Member level 1
San diego, California
directional antenna ns2
I have a small problem in my simulation, I appreciate if you could help me in debugging this. I am working on topology control and power saving in ad-hoc networks using directional antennas. Recently we found a patch for NS2.30 along with a Directional-antenna C++ Module. I installed this version and made the necessary changes made by the author. His web page was removed recently and I found the same in google catche,
On patching ns2.30 with MW-node it generated a demo example mw-node-ex.tcl in tcl/ex. I executed it and there were no errors, but after I added the C++ module and tried to execute the same code its showing me the following error.
WirelessPhy: antenna lookup of Antenna/OmniAntenna failed
ns: new BiConnector/NetworkInterface2/FullStack/Wireless 0 _o16 _o21:
(_o25 cmd line 1)
invoked from within
"_o25 cmd antenna Antenna/OmniAntenna"
invoked from within
"catch "$self cmd $args" ret"
invoked from within
"if [catch "$self cmd $args" ret] {
set cls [$self info class]
global errorInfo
set savedInfo $errorInfo
error "error when calling class $cls: $args" $..."
(procedure "_o25" line 2)
(SplitObject unknown line 2)
invoked from within
"$phy antenna [WirelessModule set wireless_param_(antenna)]"
(procedure "_o24" line 13)
(BiConnector/NetworkInterface2/FullStack/ init line 13)
invoked from within
"_o24 init 0 _o16 _o21"
(Class create line 1)
invoked from within
"BiConnector/NetworkInterface2/FullStack/Wireless create _o24 0 _o16 _o21"
invoked from within
"catch "$className create $o $args" msg"
invoked from within
"if [catch "$className create $o $args" msg] {
if [string match "__FAILED_SHADOW_OBJECT_" $msg] {
delete $o
return ""
global errorInfo
error "class $..."
(procedure "new" line 3)
invoked from within
"new BiConnector/NetworkInterface2/FullStack/Wireless 0 _o16 _o21"
Rest of the demo examples in ns2 are being executed normally. I even tried including his few lines of code that he was taking at the end in the above link. But it to turns out with the same error. Please help me if you know any thing about such sort of errors or any info on how to add a module to ns. I know you are very pre occupied and I am really stuck and I appreciate if you could help.
ns2 antenna
can u plz give me that patch,plzzzz!
my mailID:sharma.ravi70@gmail.com
ns2 directional antenna
ATTACH IS THE PATCH FOR NS-2.33 FOR DIRECTIONAL ANTENNA SUPPORT
Assuming $NS2 points to the directory where you have the ns-2.33 sources, and that you’re using the ns-allinone-2.33 release, here’s what you have to do:
cd $NS2
patch -p1 < dir-antenna.patch
patch -p1 < multi-if.patch
./configure --with-otcl=../otcl-1.13 --with-tclcl=../tclcl-1.19
make
export NS_ANTENNA_FILE=$NS2/mobile/antenna.txt
Reactions: jeccy
    jeccy
ns2 extension
hi,
thanks so much for sharing this.
do you also have a sample TCL script on how to use the directional antenna & multi-interface module? or a readme me will do as well
hope its not too much trouble
rgds,
fizi
Re: ns2 directional antenna
hello dear
could you povide a sample script ot just simple tcl command for using directional antenna?
regards
kashif
Hello
Can you post the .tcl file for directional antenna?
Thanks in advance.
-arun
I need to use directive antennas and do not know which version of ns should I use. Can you give me a patch? and can you tell me how I should install it?
my e-mail: dianyapolo27@hotmail.com
Thanks
hey
could you please help me understand the patch code !! if you have any description for it
I need to understand the antennas sending angles
thanks
Hello..,
I installed the patch for directional antennas and when i run the example “sample_long.tcl” file from TENS, i am getting the following error.
Please help me.
invalid command name “Channel/Channel_802_11″
while executing
“Channel/Channel_802_11 create _o11 ”
invoked from within
“catch “$className create $o $args” msg”
invoked from within
“if [catch "$className create $o $args" msg] {
delete $o
return “”
global errorInfo
error “class $…”
(procedure “new” line 3)
invoked from within
“new $val(chan)”
invoked from within
“$ns_ node-config -adhocRouting $val(rp) \
-llType $val(ll) \
-macType $val(mac) \
-ifqType $val(ifq) \
-ifqLen $val(ifqlen) \
-ant…”
(file “sample_long.tcl” line 51)
Can anyone please post the sample tcl script for directional antennas which gave the output.
thanks in advance,
Bharathi.
Hey,
I have the same problem as Jaya Bharathi.
Could anyone solved the problem?
Thank you
Vix
