davens
Newbie level 3
Hi. I'm using a 2N3904 NPN transistor to ground out an audio signal (from a guitar pickup). It does kill the audio signal, but pulls it to a non zero DC voltage (3mV in simulation, 18mV in practice). This is causing a click when the audio signal is small and the transistor is switched. An equivalent circuit is attached (the pickup is replaced with R13, assuming no output from the coils, and there is a sensor circuit instead of S1). I imagine this is some characteristic of transistors I don't understand? I've only really used them where the collector is pulled high.
I think what I'm asking is: could someone please provide insight into why an NPN with saturated I(BE) has a non zero V(CE) when the collector is pulled to GND?
Thanks.
Thanks.
