sweethomela8
Member level 4
I'm using devices which have a 250mA NPN output, I'm trying to use a FPGA to connect these NPN outputs to the FPGA inputs using a pullup resistor. These devices will be 50ft away from the FPGA or even more. Is there any design considerations I must take for this to be a good stable design? I've put in a strong pull-up resistor and a RC low pass filter. Is a buffer necessary even though the pull-up resistor is there? thanks.
