nitineed
FPGA and MATLAB
I want to implement basic model on NEXY-2 board , which I purchased from Xilinx company. As from the company point of view I am not getting any help.
I am faceing some basic problem regarding the input or output to/from board.
My inputs are in form of voltage and current whcih will be sensed by sensors and after processing by FPGA processor output will be 6 or 12
firing pulse which will be send to IGBT inverter gate circuit.
Here I am not getting that how input and output will be configured to the Board, means I should use some external connectors or pins or some
card for interface. I have PMOD ADC and DAC connector with bucsticks.
In general a my problem is :-
1. Let a 3 volt signal I want to send to board via some ADC card.
2. After some processing let just multiply this signal with some constant, I want to see this signal on some DSO or CRO.
This is I think the basic problem for starting, if this will run then I can understand how input and output can be managed on board.
Pl help me regarding this matter.So pl give me some solution regarding
this issue. I will be very helpful to you. Pl also provide some material regarding this board.
