Chourizo
Junior Member level 2
- Joined
- Sep 30, 2009
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Spain
- Activity points
- 1,451
Hello guys,
I´m new with HFSS. I´ve done an antenna, and build it physically, so I could compare the results of HFSS with the results of my network analyzer.
The results are not similar. With the network analyzer I can measure the gain in dB at any frequency in a range, and I get a peak around 800MHz but in HFSS I show a far field report, with the gain in dB, and the results are not similar at all.
How can I make a more real simulation? Which factors are affected? I think the key can be here:
1. Air volume around the antenna: I think it should be 1/4 waveleght or more, so for 1GHz it should be 75mm around the antenna.
2. Size of the wave port: I´ve fixed a impedance of 50Ω, but I don´t know if it should have a fixed size. Now, it´s lightly higher than the input pin of the antenna.
3. Number of the wave ports. The antenna has a signal pin and a ground pin, but now there is only one wave port.
Am I doing something wrong? Can anybody help me?
Thanks!!!
Thanks!!!
