not starting bldc motor with using sensor
grayy
Newbie level 5
Newbie level 5
hello freinds...
I could start up the motor without using the sensors (of course motor doesn't work completely continuous and the speed was very low & there were quiet short stops beetween every rotation )
anyway leave it...
when i want to start up the motor with the sensors,it doesn't move at all...it's interesting that the micro can read the sensorso..apparently high power part of my circuit works truly..
how should i do?
this is the related circuit..of course i have used IR2110 instead of 2N2222A transistors
there is IR2110 circuit in the other figure
please help
You also changed PMOS to NMOS high side transistor. How can we know what's the real circuit?
One possible problem is that IR2110 driver doesn't necessary start with static level. There must be a dedicated start algorithm.
The other point is that we don't know the sensor to output logic implemented in your processor.
The circuit is completely different now: different Mosfets, different driving mode, different count of driving signals....
So you show us two parts of schematic, and neither one is completely correct...
How do you PWM it now?
What PWM frequency?
What max duty cycle?
What does the scope show? Driver inputs, driver outputs, motor voltage...
Klaus
Without details of the sensors it is hard to be accurate, but I wonder if you should use an edge trigger from the sensor so the micro gets a " rotor passed point X" signal. At the moment you might still be getting an output from the previous sensor at the same time as the rotor generates the next sensor output.
Frank
setting up BLDC motor in PROTEUS
hello
?what is my problem in this PROTEUS circuit
please help
thanks
I attached the code but i can't attach the proteus file
  • New Text Document.txt
You don't tell an actual problem, how can we know what the problem is?
You can attach any file if you zip it before. Short code text should be appended to the post using code or syntax tags for reader's convenience.
The code suggests that you have been designing your decoder table and other details by trial-and-error method, but we don't know based on which information, e.g. motor datasheet, application note or whatsoever.
i attached it
please tell me my problem
  • simulation.zip
Your code is a real mess; if you really want help, you should at least clean up all unused comments, which accounts more lines than compilable commands. At first sight it is possible to see things apparently meaningless, for example disabling/enabling interrupt in consecutive lines, disabling interrupts within isr vector(unnecessary on CCS compiler), etc... As FvM mentioned above, you could post the code not as an attachment, but righ here on the post - enclosed by proper tags.
The code can be functionally reduced to
int8 MoveTable[8] = {0, 33, 6, 36, 24, 9, 18, 0};
int main(void)
  while (1)
    output_d(MoveTable[(input_b() >> 4) & 7]);
You don't need interrupts to run it.
But what's the problem? How are you modeling the BLDC motor in Proteus?
so your code hasn't realy used sensor feedback..in your code, we put a array on the output connected to motor...
i had attached the proteus file at already post...
i uploaded it again
  • simulation.zip
i haven't disabled the interrupt..i just have removed the flags by "clear interrupt" command..
of course i commented this comand but it didn't change anything
i attached the ordered code
  • New Text Document (2).txt
You may want to re-read this single line. Did you notice the input_b() function?
Unfortunately I don't use Proteus and can't check your simulation. A problem descriptions seems appropriate anyway.
