reza147
Member level 1
Hello
We had a few SIM800C that worked well last month. They connected to the grid after 5 seconds, and the net_LED flashed for 64 to 3000 seconds. Then we would call or text them and get them.
But a few days ago a problem occurred! These wires do not connect to the network and the net_LED always flashes for 64 to 800!
Since we have 10 of these modules, all of which have been well connected to the network in the past, we are sure that the problem is not the module or the hardware.
We used two types of SIM cards but the problem was not solved.
Our module also has an antenna.
We think maybe this week the telecommunications has been updated and now the SIM800C can not be with that matching. And GSM cannot be registered.
Can you give us an order to solve the problem?
Can anyone give an AT command for matching with the telecommunications?
Interestingly, this problem is less seen in the type of SIM808 and SIM800A!
For simplicity, we used only a SIM card, an antenna and a USB to TTL converter and a laptop.
