sushant_21
Junior Member level 3
Hi all,
I have an issue regarding LAN with esp32, So i have got designed a hardware with esp32 and dp83848 phy for ethernet connection. The problem is i dont get Link Up from phy. I am running esp32 example code PHY reset pin is 32. this is log output from board, it just stops at Ethernet started,
i have tried the connection with router and PC directly, also tried using different LAN cable, but didnt work
this is datasheet of RJ45 jack
So any help regarding this will be grateful, if any more information is needed kindly tell me.
I checked the communication between phy and esp32, this sounds good, as i tried to read phy register and below was output, i had used cyclone TCP example code for this., so this conclude phy and esp32 are communicating,V (2958) tcpip_adapter: check: local, if=2 fn=0x400e24d8
[0m
V (2958) tcpip_adapter: call api in lwip: ret=0x0, give sem[0m
V (2958) tcpip_adapter: check: remote, if=2 fn=0x400e24d8
[0m
D (2968) event: running post ETH_EVENT:0 with handler 0x400d3a84 on loop 0x3ffb4f7c[0m
[0;32mI (2978) eth_example: Ethernet Started[0m
so now i have to check between RJ45 jack and PHY, i actually dont understand what is the issue, but i am sure its between phy and RJ45 jack,Initializing DP83848...
PHY reg: 00: 0x3100
PHY reg: 01: 0x7849
PHY reg: 02: 0x2000
PHY reg: 03: 0x5C90 (this is phy address)
PHY reg: 04: 0x01E1
PHY reg: 05: 0x0000
PHY reg: 06: 0x0004
PHY reg: 07: 0x2001
PHY reg: 08: 0x0000
PHY reg: 09: 0x0000
PHY reg: 10: 0x0000
PHY reg: 11: 0x0000
PHY reg: 12: 0x0000
PHY reg: 13: 0x0000
PHY reg: 14: 0x0000
PHY reg: 15: 0x0000
PHY reg: 16: 0x0000
PHY reg: 17: 0x0000
PHY reg: 18: 0x0000
PHY reg: 19: 0x0000
PHY reg: 20: 0x0000
PHY reg: 21: 0x0000
PHY reg: 22: 0x0100
PHY reg: 23: 0x0021
PHY reg: 24: 0x0000
PHY reg: 25: 0x8021
PHY reg: 26: 0x0904
PHY reg: 27: 0x0000
PHY reg: 28: 0x0000
PHY reg: 29: 0x6011
PHY reg: 30: 0x003F
PHY reg: 31: 0x0000
